what would be a good primer to use after sanding car through clear coat
154,400 MILES • 4.3L • V6 • 2WD • AUTOMATIC
ROYCAR71
  • 359 POSTS
I haven't decided on a color yet. What primer can I use once body is done and sanded through clear coat?
Jul 30, 2015 at 7:09 AM
  • 110,248 POSTS
If everything is smooth and straight, I would recommend using a primer sealer. Any brand from a parts store should be fine. If you have imperfections, a high build filler primer can be used and quite helpful.
Jul 30, 2015 at 1:57 PM
ROYCAR71
  • 359 POSTS
Do you know if Rustoleum primer sealer will do? How long can i have car exposed sealed off before deciding to paint?
Jul 31, 2015 at 7:00 PM
  • 110,248 POSTS
That would work for you, but make sure it is going to work with the brand paint you plan to use for the final color. If the base of the primer and paint are incompadiable, the color will lift or give you a poor finish. Check with the parts store near you.
If you have the car down to bare metal, I wouldn't wait long at all to prime. The water in oxygen will cause it to rust if exposed within a few days. You should prime before leaving it for the day.
Aug 2, 2015 at 2:03 PM
  • 110,248 POSTS
One other thought... If you are sanding to the bare metal, you should us a metal prep on the areas to be painted before priming.
Aug 2, 2015 at 2:04 PM
ROYCAR71
  • 359 POSTS
My cell intention is not to goto bare metal. There are some areas that do need body work. Since car is not worth much I intend to paint with rustoleum oil based paint.
Aug 4, 2015 at 6:56 AM
ROYCAR71
  • 359 POSTS
One quick question. If I did use rustoleum do I have to goto bare metal?
Aug 4, 2015 at 7:17 AM
  • 110,248 POSTS
No. Just make sure to properly prep the vehicle before painting. NOTE: If you need to use body filler, then you will have to sand to bare metal at those places for the bondo to properly attach.
Aug 8, 2015 at 10:24 AM
ROYCAR71
  • 359 POSTS
I meant how long after priming can i leave car to outside elements before painting?
Aug 13, 2015 at 10:36 PM
  • 110,248 POSTS
The time it sits outside is really going to be based on if the metal starts rusting under the primer and bleeding through. Remember, primer really doesn't seal the metal. The paint does that.
Aug 15, 2015 at 12:27 PM
ROYCAR71
  • 359 POSTS
So primer sealer will seal or not?
Aug 16, 2015 at 8:02 PM
  • 110,248 POSTS
It should be okay for a while. Don't let it sit too too long.
Aug 17, 2015 at 6:25 AM
ROYCAR71
  • 359 POSTS
It 's been 2 weeks since car has been primer sealed. I am going to paint it in another week or so. Car is dirty from driving to and from work. Can I clean car with soap and water?
Sep 5, 2015 at 5:58 PM
  • 110,248 POSTS
Yes, it can be washed. Before painting, make sure to wipe it down with something that will remove oil and dirt. I always use the reducer which is used to thin the paint.
Sep 7, 2015 at 7:24 AM
