what is the sensor attached to the engine near PCV under the intake? i am in the process of replacing the collapsed PCV tube and I do not want to do this again.
does this sensor have a history of going bad? trying to determine what should be replaced while i am in there? any further details regarding this job is appreciated.
PS: this is the strangest design I have ever seen a PCV located. actually thought about extending the tubing to have the PCV peak out the side on intake.
thanks in advance.
thanks in advance.
Aug 16, 2017 at 11:09 AM
