what should be resistance in ohms between DISCONNECTED battery cables ?
92,700 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
MONTYNTWRK
  • 7 POSTS
i measured resistance between disconnected battery cables after seeing a big drop in battery voltage. shouldn't the resistance be infinite or very large , in the many megohm area ?
Jul 1, 2015 at 10:33 PM
HMAC300
  • 48,601 POSTS
a battery cable should be 0 ohms resistance from one end to the other. or very close to it.
Jul 2, 2015 at 12:13 AM
MONTYNTWRK
  • 7 POSTS
I meant BETWEEN the disconnected positive cable and the disconnected negative cable, NOT within each cable.
Jul 4, 2015 at 9:19 PM
HMAC300
  • 48,601 POSTS
no idea on that one, we never test for that because when you do that you are going through modules so you pick up resistance from those. Only a manufacturer might know that which they do not release.
Jul 5, 2015 at 1:11 AM
MONTYNTWRK
  • 7 POSTS
Thanks anyway. Clearly, it should be a lot greater than 4 ohms. Four ohms is like a short to ground.(There is such a thing as a short to voltage, but this is NOT that.) Imagine a battery seeing 4 ohms when the key is ON.
Jul 6, 2015 at 9:48 PM
HMAC300
  • 48,601 POSTS
because of the electronics on a car there is ALWAYS a draw on the battery due to keeping memories alive which cannot be turned off. Ohm measurement like you are talking about is never taken cause we just fix the darn things we aren't engineers....
Jul 6, 2015 at 11:32 PM
