What keeps making my car shut off
68,000 MILES • 2.0L • 4 CYL • RWD • AUTOMATIC
LEERW92
I have a Nissan Bluebird, with a new sr20 engine. It keeps shutting off while driving. I have been to mechanics and fixed various things, but they have not fixed the problem. I have installed a new fuel filter, new fuel pump, had the car scanned and a new sr20 computer. I have literally tried everything, but still the problem occurs. I have received a hint that the problem could be with the distributor. I Need your help please. What is causing this problem?
Feb 26, 2016 at 9:28 PM
HMAC300
  • 48,601 POSTS
Try cleaning throttle plate on both sides and iac hole with choke cleaner and check fuel pressure. Also check all grounds from battery to the engine and battery to the body as they may be dirty, finally try resetting the security system. If do not have a manual look online for your vehicle.
Feb 26, 2016 at 10:49 PM
