what is the life for engine
140,000 MILES • 1.3L • 2WD • MANUAL
MOHAMED ALI2
i would like to know about the engine life.
Feb 4, 2017 at 2:09 PM
SATURNTECH9
  • 30,869 POSTS
We do not have that model here in the USA, but that is a question that is really hard to say. The same engine treated the same way even could last 100,000 miles and another 250,000 miles. Some engines have weak spots like timing chains on some engines not saying yours I really do not know. what I say is always change your oil regular do not overheat the engine keep the coolant serviced when you should. Keep up the maintenance on the engine and the car in general and it will give you the longest life expectancy it can. Engines are like people some people can live a very healthy life exercising regularly etc and die of a heart attack at fifty. Then someone else can smoke daily and live to be one hundred. Just trying to give you a example you can understand. Basically life is unexpected you never know what is going to happen next. That is the best most honest answer I can give you.
Feb 4, 2017 at 11:32 PM
