what are the hoses for on a IAC valve/sensor on a 1998 mercury mystique?
1998 MERCURY MYSTIQUE
150,000 MILES
JHORNE
Sensor not bad but trying to find out what the hoses on the IAC go to could u send me a detailed diagram? I need. to see if one of them are clogged or cracked so i can get them cleaned out or replaced. thank you
May 18, 2013 at 1:36 PM
RACEFAN966
  • 5,029 POSTS
The IAC or Idle air control valve does not have vacuum hoses connected to it. It is electric and bolted directly to the throttle body. So if you go like Napa online and put in part number 339657 you will see a picture of it. If you think it is plugged you will need to go to your local parts store and get a gasket for it first then remove it and clean it. What is the problems you are having??
Jun 29, 2013 at 12:03 AM
