Water leak after rain inside car
50,000 MILES
WESTERNREACH
  • 22 POSTS
Hi, after two days of heavy rain, rain water is dripping from the driver's side sun visor hinge. The "A" pillar cover is wet (cover is velour fabric like the headliner) as is the headliner near the sun visor hinge and front seat. Car has the factory sunroof, with a full carriage top. Any advice appreciated, thank you.
May 15, 2019 at 12:47 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Sounds like it might be leaking from the actual windshield seal. Unfortunately windshields cannot be removed and resealed a replacement would have to be installed.Hope this helps and thanks for using 2CarPros.
Danny-
May 15, 2019 at 12:56 PM
STEVE W.
  • 15,390 POSTS
I would look at the sunroof drains. They love to plug up with dirt, pine needles and crud. When this happens the water pools up and leaks into the car. There is a drain tube at each corner of the sunroof. I would start by using a piece of heavy string trimmer line and gently push it through the tubes from the bottom up to try and clear the blockage. The problem is that it is real easy to knock the tubes loose and then you need to do a lot of work to remove the headliner and reconnect them.
It's a very common problem with sunroofs. You can find a lot of videos describing the various clean method online.
May 15, 2019 at 3:55 PM
WESTERNREACH
  • 22 POSTS
Thank you both for the replies. I will try to clean the sunroof drains, then if necessary, look into having the windshield changed.
May 16, 2019 at 2:21 PM
DANNY L
  • 5,648 POSTS
You're welcome! Let us know what happens and thanks for using 2CarPros.
Danny-
May 17, 2019 at 10:53 AM
