Water leak in interior
100,000 MILES • 3.0L • V6 • TURBO • 2WD • AUTOMATIC
M.GOLJAR
Water leaks passenger floor area front and rear.
Dec 29, 2018 at 7:53 PM
  • 55,682 POSTS
This can be caused by two things; first is a clogged evaporator drain tube which this video will help you find.
https://youtu.be/q9_MZiS2_NE
If have run the AC it sounds like the windshield seal has failed on the passengers side. Take a garden hose and spray it while looking with a flashlight under the dash to see if you tell where it is coming from. Please let us know what you find.
Dec 31, 2018 at 3:31 AM
