Warning lights on dash board
180,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
HAWAZ MEZMUR DESTA
I have been getting TCS, ABS, service engine, and brake lights on and off. I have changed the two downstream O2 sensors, Bank1 and Bank2 Camshaft position sensors, 2 front ABS sensors. I also have checked the brake light switch with an Ameter and found it working okay, and the likes, but for no avail. Please help me. Thanks!
May 27, 2017 at 10:50 AM
STEVE W.
  • 15,392 POSTS
Sounds like you need to get the thing scanned to see what is wrong in the braking/ABS system. Could be a bad ABS sensor/wire/connector. Or a bad ABS control module. Without scanning it and getting the codes you will not know what to look at.
May 28, 2017 at 12:20 AM
