Starts and runs. Turn key to off position with key in ignition, the warning dash lights flickering and relay clicks in ECU plastic box in engine compartment. Pull key out of ignition and warning lights stop flickering and relay not clicking. I replaced ignition switch on end of cylinder lock housing. I cleaned battery post (+/-). Cleaned many ground connections in engine compartment. Not sure if the ignition lock cylinder is the problem, or the starter relay in ecu plastic box is going bad. Or the wiring harness to ignition switch has crack in insulation touch ground or another wire.
Mar 19, 2020 at 5:38 PM
