Vsc track vsc off lights on
156,000 MILES • 0.7L • V8 • 4WD • AUTOMATIC
TESO-NY
The computer read c1336 zero point calibration sensor undone the wheels shake when I pass 38 miles and the lights actually come on when I put the car on drive it has to be move for the light to come on if is on and park they won't come on.
Jan 9, 2014 at 11:40 AM
HMAC300
  • 48,601 POSTS
this is a YAW sensor problem and apro should check this due to certain tests and if damaged in slightest way wil require a new one you need apro style scanner to read it anyhow
Jan 10, 2014 at 12:33 AM
