2004 Volvo XC90 bizarre power and engine failure 2004 XC90
2004 VOLVO XC90
69,000 MILES • 6 CYL • FWD • AUTOMATIC
BRADNIGHT
On a 6 hour drive to Los Angeles, my 69,000 miles, 2004 Volvo XC 90 experienced a severe "thump" in the front end, which was then followed by a very brief (split second) internal (meaning dashboard lights, hi-fi, dome lights, etc) power failure. Initially, the power failure would last only a split second and then car would continue running as normal, and there we no error codes or check engine lights. This happened as many as five times in a 6 hour drive.
But on the last long drive home, the "thump" was harder than usual, and the lights internally completely went out, hazard lights could not be turned on, blinkers could not be switched on, hi-fi went out, etc (though the electric windows would work).
I pulled over, and turned the car off and restarted it, and the yellow exclamation point dashboard icon/alert lit up, and a service message flashed referring to the anti-lock brake failure, and that the SRS needed to be checked.
I have it at another dealership in Northern California, who seems equally mystified and have told me that they dont think the error code of check the SRS is going to fix the problem.
Any advice you can offer would be appreciated. Thx, Brad
Sep 2, 2008 at 7:25 AM
JIS001
  • 3,412 POSTS
This types of problems are very difficult to diagnose. Sounds like you have a low can speed problem. One of the modules is going dead causing the rest of the network to go down with it. Could be a bad CEM or some relay may be going bad? As for the thump sound that is pretty strange? Be prepared to have vehicle stay in shop for a couple of weeks and numerouse test drives?
Mar 29, 2009 at 10:29 AM
