vacuum
VOLVO V90
BJSILVERMAN
98 V90 VolvoWagon, 142,000 miles, automatic.
The air conditioning often times will not blow out the vents, some time it does. I heard a pump this morning so I turned on the air and what do you know, it worked.
Probabley a vacuum leak, or is there something with the pump I heard?
Also have a wire leading to somewhere under the intake manifold but it is not connected. Any ideas?
May 15, 2007 at 7:20 PM
BJSILVERMAN
1998 volvo straight 6, 142,000
sometimes the air comes out the vents, sometimes not. yesterday, had not been working, heard a pump turn on so thought i'd try it and it worked. this am still worked. is there a pump that kicks on to creat a vacuum?
also have a wire leading to point in intake manifold but not connected to anything. any ideas?
thanks!
Barry
May 16, 2007 at 10:30 AM
