2001 Volvo V70 Changed battery on volvo
2001 VOLVO V70
138,000 MILES • 4 CYL • FWD • MANUAL
KMP36
I changed a dead battery on my volvo wagon. Now the heating & air conditioning don't work. I am told it is because there is a special way to change the battery and I have to get the computer reprogramed. Does this make sense to you?
Aug 27, 2008 at 6:38 AM
KHLOW2008
  • 41,814 POSTS
Hi KMP36,
No, there is no mention of any necessity of a special way for battery replacement.
However if there is any fault, you need a special tool to diagnose the fault.
Try to run the vehicle for it to relearn and see if it helps. Check for any blown fuses and loose connections especialy from battery terminals to fusebox.
Aug 29, 2008 at 8:37 AM
