1998 Volvo V70 car won't start
PARK2820
  • 1998 VOLVO V70
1998 Volvo V70 211000 miles
engine turns slow and will not start, starter ok
Sunday, October 12th, 2008 AT 9:19 AM
Load test the battery to make sure its in good condition and it can crank engine over 200rpms. If it continues not to start-do below and determine if its fuel or spark related problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, October 12th, 2008 AT 9:48 AM
