Electrical problem
2002 Volvo V40 4 cyl
The low beam light on the drivers side doesn't work. All of the rest of the lights work to include the blinkers, and high beam lights on both sides. I check the fuses and changed the switch. I was told I needed a CEM. What does it do and is there any way to check for a bad wire since the low beams are the only things affected. I've looked online everywhere for the part and can't find it. HELP!!!
Jan 25, 2010 at 10:31 AM
