1998 Volvo V40 indicators not working
1998 VOLVO V40
PAUL CURRIE
Electrical problem
1998 Volvo V40 6 cyl Front Wheel Drive Automatic
indicators not working even when hazard warning switch pressed any ideas how to fix ?
Sep 30, 2009 at 8:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check flasher relay
Sep 30, 2009 at 1:42 PM
JIS001
  • 3,412 POSTS
When you use the turn signal switch does the light come on only without flashing? If so, most likely the relay is bad. The relay is integrated with the hazard light switch so you would need to replace the hazard light switch. If no lights come on using the turn signal switch you may want to check the fuses first?
Oct 1, 2009 at 4:30 PM
