HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volvo
S80
Engine
Throttle Body
Replace/Remove
1999 Volvo S80
JOSH YODER
MEMBER
1999 VOLVO S80
6 CYL
2WD
AUTOMATIC
120,000 MILES
Is the throttle body hard to change opn this car?
Monday, June 7th, 2010 AT 11:28 AM
JIS001
MECHANIC
No it is not but if you dont have the equipement to program it, then your just wasting your time. Vehicle will not run. So it will be better you take it in to the dealer or a shop that can do the programming.
Tuesday, June 8th, 2010 AT 12:54 AM
Please
login
or
register
to post a reply.
Related Throttle Body Replace/Remove Content
1999 S 80 Volvo
1999 S80 Seems To Run Out Of Gas And Then Suddenly Its Normal. Does The Throttle Body Work Off Electronic Device. I Removed The Intake No...
Asked by
delkja
1 ANSWER
1999
VOLVO S80
2000 Volvo S80 Cars Act Funny When I Press On The Gas
Engine Performance Problem 2000 Volvo S80 6 Cyl Front Wheel Drive Automatic 180 K Miles Ok Well Let Me Try To Discribe This The Best I...
Asked by
mangoman86
2000
VOLVO S80
1999 Volvo S80 Do I Just Need A Atf Oil Change Or A...
1999 Volvo S80 129900 Miles I Have Had This Gorgeous Volvo, Second Hand, For Two Months. No Signals Of Problem, No Funny Noises...
Asked by
margotlechat
1999
VOLVO S80
1999 Volvo S80 Exhaust Camshaft Position
I Have 1999 Volvo S80 Turbo. I Have Obd2 Code P0014 It Says (exhaust Camshaft Position) Code. What Do I Have To Fix To Get Rid Of That Code.
Asked by
khris916
1 ANSWER
1999
VOLVO S80
2002 Volvo S80 How To Adjust Idle?
How To Adjust Idle?
Asked by
Tirone
2002
VOLVO S80
VIEW MORE
Throttle Bore Service - Chevy
Throttle Body Service Chevrolet
Service Throttle Body Toyota Highlander V6
