1989 Volvo S70 Engine Makes Noises
250 MILES • 6 CYL • AWD • AUTOMATIC
LAURA SANCHEZ
I turn my car on and it started makeing a noise I had to drive it home from work and after a while the noise stoped, I parked the car but now that I tryed to take it to a mechanic it does not turn on it feels like it wants too.
May 6, 2010 at 7:43 AM
JIS001
  • 3,412 POSTS
What kind of noise was it making? When you try to start the vehicle up, does it crank over and is it a strong crank or does it feel like it is turning over very slow?
May 7, 2010 at 7:13 PM
LAURA SANCHEZ
When you turn it on it feel like its turning over very slow but wont turn on
May 11, 2010 at 9:44 AM
JIS001
  • 3,412 POSTS
If it is cranking over very slow you could have a weak battery. You need to have the battery tested and have the charging system checked. Also have the shop do a voltage drop test across the positive battery cable. They go bad most of the time having high resistance.
May 12, 2010 at 4:04 AM
