2002 Volvo S60 thermostat
2002 VOLVO S60
12,900 MILES • 4 CYL • 2WD • AUTOMATIC
ROGGEN22
I replaced my bad thermostat and I am having a slow leak of anti freeze. I replaced the gasket twice and tightened the housing. It does not appear to be leaking from the housing, but that is all that I touched during replacement, any thoughts?
Jan 23, 2009 at 2:41 AM
DOCFIXIT
  • 18,828 POSTS
Is it leaking between housing and intake? if yes then housing mate surface maybe warped. Remove and put straight edge on it. If comming around bolts coat threads with No. 2 permetex or similar.
Jan 24, 2009 at 3:42 AM
