2002 Volvo S60 Removing a Harmonic Balancer For a 2002 Volv
2002 VOLVO S60
JMERC2889
Engine Mechanical problem
2002 Volvo S60 Two Wheel Drive Automatic 105000 miles
I am replacing the timing belt along with the water pump on a 2002 S60 for it's 100K service. Is there a specific tool for removing the harmonic balancer or will a jaw type puller for pulleys work. I was told the standard puller you would use is the same as the steering wheel puller, but that does not sound right.
Apr 21, 2010 at 12:45 AM
JIS001
  • 3,412 POSTS
Once you remove all the bolts, reinstall the crankbolt but do not install all the way. Use apry bar and pry on the crank pulley. That willl pop it out for you. Hope this helps.
Apr 21, 2010 at 1:56 PM
