2000 Volvo S60 idle
2000 VOLVO S60
101,000 MILES • 4 CYL • FWD • AUTOMATIC
MUSHER56
Hi..I have a 2000 Volvo S60 5cyl. Auto. I'm getting a surging idle only when in park or neutral. Engine will surge up to normal idle then decline. It is a constent surge. This does not seem to happen at all in gear. I was wondering if maybe the throttle body was dirty or maybe a sensor you may know about.
Thanks,
Dave Allen
Dec 5, 2009 at 2:40 AM
JIS001
  • 3,412 POSTS
You could have an issue with throttle itself. Looking by the year on your car the extended warranty may be due here soon. The electronic module has a 10 year/200k mile warranty on it so I recommend you call Volvo to verify if the warranty is good? If it is they need to do some tests on the throttle to verify it is failing. Good luck.
Dec 5, 2009 at 2:48 AM
