Hello I would like to change the timing belt and water pump in my Volvo.I never did that on volvo.Can I get some instructions please.
Regards
Sep 30, 2008 at 11:06 PM
JEFF LYDIC
MEMBER
Just an FYI, you do not need to replace your timing belt until 105,000 miles or if you have VIN Code #59, it isn't do until 120,000 miles. Also, Volvo does not have a interval when you need to replace your water pump. The things that need to be replaced with your timing belt, is timing belt, tensioner, fuel filter, and aux drive belts.
Nov 17, 2008 at 9:44 AM
