2003 Volvo S40 runs rough
RUIZLIDOS
Engine Performance problem
2003 Volvo S40 4 cyl Front Wheel Drive
the car was running a little rough when we bought it(used of course). Replaced timing belt, water pump, plugs, and intake manifold gasket. Ran great for about a month then started getting a really bad miss. Checked the plugs and two of them had shattered along the porcelain. Is this due to bad coil packs?
Jan 27, 2009 at 1:19 PM
DOCFIXIT
  • 18,828 POSTS
Sounds more like detonation ie. spark knock. Is a check engine light on? Maybe high combustion temps. Check EGR operation if not opening temps will rise. Also are there black spots on porcelian?
Jan 29, 2009 at 1:31 AM
