2001 Volvo S40 Transmission has a hard shift after 3000rpm
2001 VOLVO S40
STILTZMF
Transmission problem
2001 Volvo S40 4 cyl Front Wheel Drive Automatic
I just finished repairing an idling problem by replacing the ECT sensor. The Idle control Valve cleaned and was not the problem. While test driving the car, it all of a sudden shifted very hard, a check engine light came on and an UP arrow became visible blinking. When I got it home the following error codes were present: 700 and 704/705, not sure which of these codes were present. One or the other either way. I have not yet checked the fluid level in the transmission, but the car has not been driven in over 5 months. Any ideas
Mar 2, 2010 at 4:20 AM
JIS001
  • 3,412 POSTS
The check engine light will have a code to indicate the transmission control module has posted a trouble code since the arrow light is. Now for PO700 codes, those will be transmission fault codes and I can not seem t find info on 704/705 codes. Is it possible for you to have the transmission control module scanned for codes?
Mar 3, 2010 at 5:03 PM
