2001 Volvo S40 P0107 and P0101
BRALDEN
  • 2001 VOLVO S40
Engine Performance problem
2001 Volvo S40 4 cyl Two Wheel Drive Automatic
Hi. This is a 2001 Volvo S40 1.9L turbo. I've been having much less power on acceleration and engine roughness or stumbling accompanied with occasional stall and codes P0107 and P0101. I've already replaced the MAF and the MAP sensors and spark plugs. Before the codes would erase and come back later. Now they will not erase. Does the MAF need to be calibrated aka "reset MAF adaptations" at the dealer like Mercedes Benz? Any info solving this headache would be great.
Thursday, July 8th, 2010 AT 5:39 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,162 POSTS
Hello, if the car has many miles on it the turbo condition will cause the problems you have described. Remove the exhaust portion of the turbo and check for engine oil deposits. If excessive oil is present the turbo has failed and needs replacing, please inspect and get back to me with your findings. Thanks for using 2Carpros. Com
Monday, July 12th, 2010 AT 5:53 PM
