2000 Volvo S40 resetting radio
2000 VOLVO S40
113,000 MILES • 6 CYL • FWD • AUTOMATIC
JOANNE04090
we had to remove the dash board, when we reinstalled it the radio came up asking for a code we entered the wrong code and now all the radio says when you turn it on is OFF is there a way that we can reset it to ask for the code again, I have the right code this time
Sep 8, 2009 at 10:56 AM
STARNET
  • 8 POSTS
the ignition key turn to the position 1, the radio unit must be on.than you have to wait around 2 hours NOT LESS.. radio will turn it self to the CODE position...and than enter the right numbers...while you r waiting make sure all lights r off or u will and up with flat battery... hope it will work.. by the way I need radio code for s40 2001 radio HU-605 if u have it post it to h.dal01@gmail.com goodluck..
Nov 1, 2009 at 1:19 AM
