Volvo All Wheel Drive problem
VOLVO
MCZYZ
We just had a heavy snowstorm, and my 2004 AWD 5 cyl. Volvo got stuck....the front tires were majorly spinning, while the rear tires did nothing. Can anyone point me in the right direction of what could be the problem? The car has 25k miles.
Mar 17, 2007 at 7:02 AM
DAVE H
  • 13,383 POSTS
The differential distributes power equally between the drive wheels, even if they are rotating at different speeds.
When driving straight ahead, the ring wheel and differential housing rotate at the same speed as the drive shafts and the driving wheels.
When cornering, the differential gears rotate to compensate for the different speeds of the wheels. Because the small side gears are rotating on the shaft journal, the drive shafts can rotate at different speeds. Power is transferred from the differential housing to the drive shafts via the small side gears in the same way as when driving straight ahead. Both drive wheels still have the same driven power.
Cars with four wheel drive have a splined pin on the differential housing. The sleeve on the pin connects the differential housing with the bevel gear. This transfers the power to the rear wheels.
Jan 16, 2010 at 10:32 PM
