One problem I have with the writers is what the actual complaint is? Does it blow cold or not and if it does, does it quit blowing cold when it is too hot? The real answer will be if I could actually drive with you? If it is not blowing cold enough then you are most likely low on freon. If it has being very hot where the temp has being triple digits or very humid then sorry, there is nothing anybody can do because it is too hot for the A/C to cool. If it blows cold and then gets warmer when hot, then you could have a worn compressor clutch? So which complaint do you have?
SPONSORED LINKS
Sunday, August 29th, 2010 AT 2:28 AM
