2002 Volvo C70 Excessive Gas Mileage Decrease
2002 VOLVO C70
29,000 MILES • 4 CYL • 2WD • AUTOMATIC
PFETNER
After a "full tune-up" w/all new sparks, oil, fluids, etc. I drove from the mechanic & instantly went from 20mpg to 12.5mpg. There is also a strong smell of gas when I now start up which lasts for about 1-2 minutes. I went back to the mechanic & he informs me that it's an electrical issue. I ask that you arm me with other possibilities before he starts messing with yet another area (if I go back to him at all). Thanks
Aug 27, 2009 at 2:54 AM
JIS001
  • 3,412 POSTS
Has the check engine light come on? If it has then the code can give you an idea as to where to start diagnosing. You can have a dead oxygen sensor where it is telling the ECM there is a lean running condition causing it to make it run richer. You can have a faulty engine coolant temperature sensor foolling the ECM it is still cold making the ECM to run richer to try to get it to warm up faster but usually if that happens you can also have a very high idle. You can have leaking injectors also? Also how is the driveability? After the repair did it run worse? You need to have it diagnose to see what the problem is. If you do not trust what the shop says take it in to another shop for a second opinion.
Aug 27, 2009 at 6:19 PM
