ignition key stuck
VOLVO 940
PADDY35
my vehicle is a 1994, Volvo,940, Turbo, 4 door, with 200,000 miles. Engine is a B230FT. It recently threw the alternator belt which I repaired. The car starts fine, goes into gear fine (automatic trans) runs fine goes into Park fine and turns off fine. Ignition key won't come out. i tried unhooking/rehooking the battery. I tried jacking around with the steering wheel and gear shifter. There is a shift-lock fuse which I did "not" check because according to the manual, other items on the same circuit are still functional. (Eg: turn signals)
I am a broke, Paramedic Volunteer and it would be a drag to have my car stolen off a scene. The Volvo dealership will gouge me. Thanks ahead folks!
Mar 21, 2007 at 11:22 AM
MIKE H R
  • 3,094 POSTS
the key might be stuck in the ignition cylinder with the key in the off position { where it would normaly come out}, try a little lube onto the key, work the key in and out as much as possible, working the lube in. not sure if this is the problem, but its worth a try.
Mar 22, 2007 at 9:10 AM
