1993 Volvo 940 Knock Sensor?
1993 VOLVO 940
DESIREEFERNANDEZ
Engine Mechanical problem
1993 Volvo 940 6 cyl Front Wheel Drive Automatic
My Volvo has been dying often and with no warning. I took it to a mechanic and he changed the knock sensor, but a few months later it starting dying again. Some says a few times then starts up again after sitting, and then I can drive a few days with no problems.
Sep 25, 2010 at 3:35 PM
VOLVO SERVICE ADV
  • 175 POSTS
THOSE ENGINES ARE HARD TO DIAGNOSE. THE BEST WAY TO PINPOINT THE SOURCE OF THE PROBLEM IS TO HAVE THE CONDITION PRESENT AND HAVE A MECHANIC CHECK RIGHT THEN. THIS WAY YOU ARE ABLE TO FIND OUT EXACTLY WHAT IS CAUSING IT. OTHERWISE, IT IS A GUESS AND YOU MAY OR MAY NOT HIT IT RIGHT.
Sep 27, 2010 at 3:27 AM
