Coolant in Turbocharger
VOLVO 850
ROGER73
Volvo 850 Turbo, 1994, 112,000, 2.3L; The water pump on the car went out while driving on the freeway, after replacing the water pump I began to refill the cooling system with coolant. Coolant ran out of the back of the engine. I traced the leak to the turbo charger, when I pulled it off coolant ran out of the chamber on the exhast side, there was no evidence of coolant in the exhaust system. Why would I have coolant inside the turbocharger? I tried to donate but the link did not work.
Nov 28, 2007 at 3:20 AM
2CARPRO JACK
  • 11,533 POSTS
Coolant is used to kep it cool, maybe it has a small hole inside that is letting it in. Sounds like a fairly rare problem. Try plugging one side of the turbo at the coolant line and lightly pressurize the other and see if it holds
Nov 28, 2007 at 11:36 PM
