1990 Volvo 740 idiot lights
140,000 MILES • 4 CYL • FWD • AUTOMATIC
LILLIES4EVER
what can cause my idiot lights to stay on when car is running
Jan 13, 2008 at 11:42 PM
KNOXMORE
The idiot llights (test mode) should be on when the ignition is on and no AC (yes, AC not DC) is detected from the alternator. This voltage is contected by a single wire using a push-on spade connector to the back of the alternator. Try disconnecting this and re-connecting in case of simply a corroded connection. It happened to me. Note: if you have a tac, it uses the AC to calculate the RPM. If this AC connection fails, the tac drops to "0".
Jul 1, 2008 at 7:47 PM
