1982 Volkswagen Van timing bosch injection pump
16,000 MILES • 4 CYL • 2WD • MANUAL
E.WRIGHT
Having removed the duesel injector pump for repair I am unsure how to accurately replace it. I have also replaced the cambelt and can lock the camshaft and locate the tdc flywheel marks but I seem to have no reference marks on the pump gear wheel as to injection point. It is a Bosch pump with manual lever attachment for cold starts
Jun 18, 2009 at 8:16 AM
DR LOOT
  • 2,311 POSTS
I have two of these diesel vans, you're going to need to go to your local European parts store and order in a kit to be able to set up the injection pump it requires three special tools, it will cost you about $80 for the tools, you will also need to order a factory manual for the diesel and follow the instructions precisely or you will ruin the whole job. The reason you cannot find the marks is because you don't know what you are looking for that's why you need the manual. anymore questions on the setup procedure let me know I am an expert.
Jul 11, 2009 at 7:51 AM
