1972 Volkswagen Van starting
GUTZ714
Engine Mechanical problem
1972 Volkswagen Van 4 cyl Two Wheel Drive Manual
the engine started then stoped and would not turn over at all i thought it was siezed but i took the he ads off and the pistons sled in the barrels easy but it still wont turn at all its like the crankshaft is frozen
Jan 9, 2010 at 8:42 PM
DR LOOT
  • 2,311 POSTS
Did you remove the other head as well? Remove the starter make sure it is not jammed into the flywheel.
Due to the high level of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 19, 2010 at 1:44 AM
