2002 Volkswagen TDI Brakes squeeking and pulsing
170,000 MILES • 4 CYL • FWD • MANUAL
CHEESEMAN
My wife is complaining that the brakes are really starting to squeek and I noticed they seemed to pulse when I drove the Jetta TDI recently. What kind of brakes would this car have and is it a tough job to undertake? Going to a foreign car repair shop is very expensive, so I'm thinking of tackling this myself with a friend who typically is quite good with cars.
Mar 31, 2010 at 5:34 AM
2CARPRO JACK
  • 11,533 POSTS
If the fronts are pulsing, the rotors may be warped.If they are making noise , you may be looking at a full front brake job.I would suggest new rotors at that mileage, they most likely have been machined before, and the thinner they get the easier they will warp.Also use a high quality pad, OEM (Original Equipment Manufacturer) if the budget will allow it. Go here and you should find the info you ned to handle this job
https://www.2carpros.com/how_to/how_to_replace_brakes.htm
Apr 1, 2010 at 1:02 AM
