2001 Volkswagen Passat P420 and P430 trouble codes possib
LA GANZA
  • 2001 VOLKSWAGEN PASSAT
Engine Mechanical problem
2001 Volkswagen Passat 6 cyl All Wheel Drive Automatic
HI I have 2001 passat 6 cylinders engine light on getting trouble codes P420 and P430 any ideas of possibles causes. And my I dont get hot air on my heater whats wrong? Thanks for any help
Saturday, September 12th, 2009 AT 12:02 AM
DUBTECH
  • 159 POSTS
Those are catalytic coverter efficiency codes.
Depending on mileage your car may still be covered under the emissions warranty. It may be worn catalytic converters, improperly working oxygen sensors, or just in need of an ECU reflash to reset the efficiency parameters.
The heater is a separate issue and is probably due to a clogged heater core. You should have the climate control system scanned for any fault codes to rule out any control head or blend door malfunctions first.
Monday, September 14th, 2009 AT 1:11 PM
