The clutch pedal switch is incorporated into the starting system, so you'll need to test or bypass it for further diagnosis.
Try testing the voltage at the starter again while turning the key harder and wiggling it. Sometimes this technique can verify that the ignition switch is bad.
If it is bad, the electrical portion of the ignition switch can be changed without having replace the mechanical portion.
SPONSORED LINKS
Wednesday, September 9th, 2009 AT 11:40 AM
