Oil pressure indicator light
VOLKSWAGEN
RODI
1998.5 Audi A4 2.8L Quattro 83k miles:
The oil pressure warning appears when the weather is warm (over 65 degress); never happens during the winter months. When the oil temp goes above 225 degrees, the warning appears. This usually appears when I am idling in traffic and it disappears when I start driving. The warning light becomes more frequent when it gets hot and humid in Chicago and I have the air conditioner running. My oil level is correct and this appears even after an oil change. What is causing this?
May 15, 2006 at 1:02 PM
IMPORTBASHER89
  • 29 POSTS
either its idled too low or your oil pump is bad or the oil pressure sending unit is bad. You need to get a live oil pressure reading first (using a oil pressure gauge)
May 17, 2006 at 7:32 AM
