IGNITION PROBLEMS
VOLKSWAGEN
CLYDE493
I HAVE A 2003 VW JETTA 2.O LITER ENGINE WITH 135,000 MILES. MY CAR WILL NOT SHUT OFF. I HAVE CHANGED THE IGNITION SWITCH , THAT IS NOT THE PROBLEM. YOU TURN THE CAR OFF ENGINE STILL RUNNING AND THE KEY WITH COME OUT. I'M ALSO HAVE PROBLEMS WITH THE FUEL INJECTORS THE CAR IS RUNNING RUFF AND WILL NOT EXECERATE. THIS JUST STARTED.
Jun 12, 2007 at 12:06 PM
TURBOTAIL
  • 30 POSTS
I have the same problem I have to disconnect from the battery terminal to shut it off
Dec 6, 2007 at 4:57 PM
