1997 Volkswagen Jetta GT Hard Shifting
1997 VOLKSWAGEN
SMITTY_KITTY_678
A few months ago, my automatic Jetta started shifting hard in to second gear, but only when it was cold, and only right after I started it up. When it warmed up, no problems.
Recently, it started doing the same thing going from a stop, in drive, to first gear.
The engine revs to about 40 rpm before catching.
With previous cars I've owned, I would have flushed the transmission. Apparently you can't do this on my Jetta, it is a "sealed system". According to the dealership, a flush is very rarely done. Personally, I don't get it. Sealed system or not, the fluid must get dirty.
I am unsure of what to do. A friend suggested having the computer timing adjusted? If anyone has a clue about what's going on, please help me!
Jan 16, 2006 at 5:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You need to have the tranny fluid/filter changed, not flushed. Flushing the tranny fluid is different than simply changing it and can not be performed nor is it recommended on all vehicles.
Thanks for using 2CarPros.com!
Mar 4, 2009 at 2:39 AM
GABRIELJORGE
I have similar problem and I change the speed sensor of the transmission and the problem was gone, the engine light never was on .
Mar 6, 2009 at 2:56 AM
Suggested Repair
Have the transmission fluid and filter changed rather than flushed. A fluid-and-filter service is different from a flush and is the recommended approach.
Conversation Summary
The owner of a 1997 automatic Jetta GT reported hard shifts into second gear when cold, and later hard engagement into first from a stop, with the engine revving before the transmission caught. The owner noted the transmission was described as a sealed system and that a dealership rarely performs flushes. An expert advised changing the transmission fluid and filter rather than flushing, explaining that a flush differs from a fluid change and is not recommended on all vehicles. Another user reported a similar issue that resolved after replacing the transmission speed sensor, with no check-engine light.
