1997 Volkswagen Golf Timing Belt
VOLKSWAGEN
PHILM97GOLF
Hi everyone, '97 Golf, original owner, 85,000 miles, well maintained. We will be taking a 4,000 trip next month so I'll be having everything checked out before we go. I've just got new tires and brakes and the clutch is good. My concern is the timing belt. VW doesn't seem to have an opinion on maintenance for the belt. Is there a way to check the condition of the belt? Should I just have a new one installed? Any idea of cost for this (will have to go to dealer or very good mechanic to have done)? The car runs perfectly and has been one of my most trouble-free VWs ever.
Thanks for your time...
Phil
Jan 22, 2006 at 4:50 AM
2CARPRO JACK
  • 11,533 POSTS
At 85 k I would have it replaced. Dealer or trusted tech, the choice is yours. Be sure the tech(non dealer) uses OEM parts
Feb 10, 2006 at 8:42 AM
FRIEDEMANN
  • 47 POSTS
It is strange that VW doesn't give you the info on belt changes. Every manual and VW here says 60,000 miles it is changed regardless what it looks like.
It is a lo cost item $26.oo here(not from VW) and half hour of work.
A broken belt means a motor job....
Dec 13, 2006 at 11:40 AM
Suggested Repair
Replace the timing belt now. At 85,000 miles it is past the commonly cited 60,000-mile interval, and appearance is not a reliable guide. Have a dealer or trusted technician do the work, and use OEM parts if it is not done at the dealer. A broken belt can cause major engine damage.
Conversation Summary
The owner of a well-maintained 1997 Volkswagen Golf with 85,000 miles asked whether to inspect or replace the timing belt before a long trip and what it might cost. An expert recommended replacement at this mileage by a dealer or trusted technician using OEM parts. Another reply said manuals call for replacement at 60,000 miles regardless of appearance, noted the belt itself is inexpensive, and warned that a broken belt can require major engine work.
