Thanks!
1998 VW Jetta Trans Fill Plug
1998 VOLKSWAGEN
I have a 98 VW Jetta GL 2.0L with 140K miles. The 5 speed manual transmission sounds like it needs fluid. I know the manual calls for synthetic 75-90W oil, but where do I pour it in? I can find the drain plug underneath, but don't know where the fill plug is located.
Thanks!
Thanks!
Jan 7, 2007 at 9:39 AM
On manual tranny's there are actually what look like two drain plugs. The one is an actual drain plug but the other is the fill plug. The only difference is the height or location of the plugs. One is low and one is higher. Look and you will find the plug. The oil jugs you purchase usually have a squirt top. Now let me add this to the mix.
If the tranny takes any more fluid than a squirt, read on, but I would hope that when you unscrew the plug there is fluid slowly oozing out. If not and it seems that the tranny is taking a bit of oil, I would first of all watch it closely. If you have to add again, while down there look for possible leaks. One place to start looking will be where the axles are inserted in to the tranny. The seal could be leaking. Once the CV axle is popped out, which is a fair amount of work but very doable by a DIYer, the seal can be popped out and replaced.
Hope this helps and good luck!
Jan 8, 2007 at 1:43 AM
Suggested Repair
The fill plug is the higher of the two similar plugs on the manual transmission; the lower one is the drain. Fill with the specified synthetic 75W-90 using a squirt-top bottle until fluid slowly oozes from the fill opening. If it takes a significant amount or needs topping up again, inspect for leaks, especially the axle seals where the CV axles enter the transmission, and replace a leaking seal after removing the axle.
Conversation Summary
The owner of a 1998 VW Jetta GL 2.0 with a 5-speed manual cannot find the transmission fill plug and only sees the drain plug. The expert explains that the higher of the two similar plugs is the fill plug and advises watching for leaks, particularly at the axle seals, if the transmission is low and needs fluid again.
