2003 Volkswagen Jetta Stalls and Resets
It sounds like you are having a ton of problems. But here is what is confusing me. You stated "Ever since we have had nothing but problems.". Not really sure what the problems you r are having. I know before you said it would just quit and die after some beeps, but is that what it does everytime? the reason I ask is because some of the things done to your car are not really related with your listed problem.
So, if you can try and be more specific on what the car is doing, then maybe you will get some better input.
Did you ask the dealer what the beeps meant?
They continue looking at the electrical system because for some reason you are loosing power intermittanly.
Maybe you can do a little troubleshooting yourself. Try and look at the ignition switch and see if it looks like it has been messed with. With the engine running, jiggle the keys and press on the sterring colum to see if you can induce the problem.
Good luck, and please let us know what fixes it.
Suggested Repair
Inspect the ignition switch and related wiring for damage or tampering from the break-in. With the engine running, gently jiggle the key and press on the steering column to see if the stall or reset can be reproduced, since the symptoms suggest intermittent power loss.
Conversation Summary
A 2003 Volkswagen Jetta wagon 1.8T began stalling or resetting after a battery replacement following a break-in. Three long beeps are followed by the engine shutting off or the dash resetting, often at idle or when pulling away. Prior throttle-body, vacuum-hose, battery-terminal, fuse-box, and alternator work did not fix it. The expert suspected a damaged ignition switch or related wiring and suggested inspecting the switch and trying to induce the fault by moving the key and steering column.
