2003 Volkswagen Jetta Cannot open trunk
2003 VOLKSWAGEN JETTA
YETTA OH THREE
Electrical problem
2003 Volkswagen Jetta 4 cyl Two Wheel Drive Manual 91K miles
I am unable to open the trunk. The key does not work when placed in the lock. I am unable to use the switch inside the car. The button on the remote key does not work. Can you help me diagnose and troubleshoot this problem. Thanks
Aug 9, 2008 at 10:35 PM
AZTEC00
You may have a brocken latch inside your trunk,go inside your trunk trough your back seats ,open it manually,once open replace the broken latch,you need to remove inside trunk lid cover to do it....
I am unable to open the trunk. The key does not work when placed in the lock. I am unable to use the switch inside the car. The button on the remote key does not work. Can you help me diagnose and troubleshoot this problem. Thanks[/quote]
Aug 10, 2008 at 11:09 AM
