2000 Volkswagen Jetta
B.C.
  • 2000 VOLKSWAGEN JETTA
Computer problem
2000 Volkswagen Jetta 4 cyl Front Wheel Drive Manual 190000 kl
check engine light obd11 code p0605
had it in the shop and they cant find anything wrong.
All systems check out? Any sugjestions
Tuesday, July 20th, 2010 AT 7:51 PM
EDWARD.S
  • 166 POSTS
Hi, The Code Is a Control Module Ram Error Code. The ECU For That Car Is Under The cowl. Remove The Plastic Panel To The Rear Of The hood. Disconnect The Battery, Remove The EcU From the car, Remove The Torx Screws Holding The ECU Together, There Inside The ECU Is A Three Inch Piece Of rubber Hose carefully Remove and Replace It. Reinstall The Ecu, Reconnect The Battery. Have The Code Cleared.
Hope This Helps You,
Good luck
Edward S.
Tuesday, July 20th, 2010 AT 8:22 PM
B.C.
Had the shop pull the ecm on the jetta
there is no rubber hose on this one?
Wednesday, July 21st, 2010 AT 12:42 PM
EDWARD.S
  • 166 POSTS
Sorry, This Did Not Help You, I'm Looking For More Info On It.
Edward S.
Wednesday, July 21st, 2010 AT 7:23 PM
EDWARD.S
  • 166 POSTS
Hi, There Is a Technical Service Bulletin For your Car. Vw Says That Code Po605 Can Be Stored In memory Due To Low Battery condition. Do Not Automatically Replace The ECM For This condition. First, Perform The following: Verify That Battery Voltage And condition Are OK.(Charge And Load Test As Necessary)If Battery Voltage Is Low: Correct reasonFor low Battery Voltage. With Battery Fully Charged :Clear Any Stored Dtc. Perform Throttle Adaptation Procedure(see Repair Group24, ECMto Throttle Valve Control Module, Adaptation. Test Drive Vehicle for Approximately one half hour. If MIL Light Does Not Stay On And DtcDoes Not Return:Low battery Voltage Has Most Likely Caused The dtc To be stored. Procedure is Complete. If MIL Light Comes back On And Stays on, And Dtc Is Stored Again, Perform The Following: Replace ECM.
Reference Numbers: Group 01, No.07-24 (2010582)Date Of Issue: February 23, 2007
Edward S.
Thursday, July 22nd, 2010 AT 8:29 PM
