Monday, September 14th, 2009 AT 1:31 PM
Engine is 2.0l. Gas. Coil tests OK. Battery OK. Distributor OK. Crank sensor?- Coil is getting signal from it, I believe. Car was starting and running fine. Then nothing-as tho an ignition cut-out switch was interfering. Tried ign. Switch. Trans. Is in park. Only other interruptor I'm aware of is car alarm. Not sure how to check that. Any ideas? Thanks, Jon
