1998 Volkswagen Jetta Engine stalls
RODTOPDOG
  • 1998 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • MANUAL
  • 252,335 MILES
My car runs and after 10 to 20 minutes stalls out. I have already changed the radiator coollant sensor, fuel pump and it still does it.
Monday, August 10th, 2009 AT 9:16 AM
STEVEW84
  • 673 POSTS
Do you have any codes? Does it start right back up after it stalls?
Monday, August 10th, 2009 AT 12:08 PM
RODTOPDOG
No codes and after about twenty minutes it starts again. It cycles like this wether I drive it or just sits idling.
Monday, August 10th, 2009 AT 12:35 PM
STEVEW84
  • 673 POSTS
What are you missing when the car does not start? Fuel, spark, inj. Pulse?
Monday, August 10th, 2009 AT 10:45 PM
RODTOPDOG
I have changed the spark plung, cables, distributer cap, fuel pump, coolant temperature sensor and filled up the gas tank. Engine turns but it just wont start untill about 15 to 20 min. Runs for a bit the stalls again and goes thru the same cycle.
Tuesday, August 11th, 2009 AT 9:50 AM
STEVEW84
  • 673 POSTS
Ok, so have you checked fuel pressure, spark, and inj. Pulse when it will not start? If so, what are you missing?
Tuesday, August 11th, 2009 AT 12:31 PM
