1990 Volkswagen Jetta car runs for a while then dies
100,000 MILES • 4 CYL • FWD • MANUAL
MIKOWILLIAMS
i drove a couple hundred kilometers in one day and it was raining extreamly hard and since then when im driving without any warning the car just dies and sometimes restarts imideatly and other time takes over an hour to start i replaced the air filter because it was wet and the distibutor cap because it was worn but the problem hasnt stopped
Oct 20, 2009 at 11:43 AM
ILOVEMYVWJETTA
You need a new tune up iam talking spark plugs and spark wires and rotors and cap and distrbuter cap . had same issue. check ur mass air flow sensor also
Dec 30, 2009 at 5:58 AM
JAY80
  • 5 POSTS
It is more than likely the fuel pump on the out side of the car. There is one in the tank and one in line. It is located by the pass. side back tire. It looks like a square box. I have a 1990 jetta and i will be driving down the road and it will die. I can hear the pump making noises and when it makes a certain high pitch noise it will fire right up.
Jan 2, 2010 at 1:40 AM
